![](/profile/get-photo.asp?memberid=9&type=profile&rnd=173) The Original Lock Springs Rver Rat | No cart driver would be setting the speed as long as I was running the combine,their only job is to follow the combine,down corn,heavy green beans you name the combine operator should not be worrying about following the cart,just keeping his eye on the job in front of the head. I should add that the combine operator can swing the auger back and forth to load the cart,no need for the cart to change position.
Edited by Don NMO 10/16/2006 22:23
