| Nope, there is no real easy way.
Not unless you infill lines are made at a specific compass heading, you could sit at the tile inlet, offset, then strike an A+ line.
If you want to make the line you want permanent, you can skip the first time. Skip a second time, then sit on the line perfectly online. Re load the ORIGINAL line, then SHIFT a whole number of rows closest to where you are either an even or odd number of rows, and your new SHIFTED AB line WILL align with your Original line.
I've never worried about it over the years, I have made a few lines that are an offset, but by the time I am done I have to REMEMBER to use that line when I am close to the obstacle I am trying to avoid, and during planting, I never seem to remember. | |
