Search Forums | Classifieds (1) | Skins | Language
Importing Field Boundaries onto Pro 700
torn
Posted 6/6/2023 09:32 (#10259153 - in reply to #10259084)
Subject: RE: Importing Field Boundaries onto Pro 700
roaming
steigerfan - 6/6/2023 07:38
So if I'm understanding this correctly, the shape file folder has to be shapefile.cn1?
I guess I'm kind of confused on this same level thing
nope. If you put your USB stick in a PC and open it up, you should see:
xxxxx.cn1 (this is where all of your logged data is stored, including guidance lines, planter data, sprayer data, growers, farms, fields, etc.)
shapefile (this is the folder where you need to put all of your Shapefiles. Just dump them all in together.
(You might also see a TaskData folder, if you use any ISOBUS implements.)
If the "shapefile" folder is INSIDE the cn1 folder, the display won't find the Shapefiles. So make sure that you can see the folder named "shapefile" while you can also see the folder ending in .cn1
Edited by torn 6/6/2023 09:34
