Near Intersection of I-35 & I-90 Southern Mn. | It depends what you want out of the system. If you want to get speed from the 500 to the Raven 450 that is one issue. Then the Raven could control the spray rate as usual but would not have auto section control.
It should be possible to use a relay triggered off of the Raven master to create a coverage map. The coverage map would be all or nothing.
I did this with a 750.
If you want section control or section control and rate control then the EZ-Boom would get involved.
This would be what I consider a clunky system but could work for you. |
