roo - 6/9/2023 18:59
Tractor has no speed on the dash. Rate controller still has radar speed. Exchanged speed sensor with my 8670. Still no speed on dash. Code 340 and 345. Tractor runs and shifts fine but will not go above 10 gear. Figuring the not sensing speed is not allowing it to go above 10th gear. Tried following the wiring harness but it goes under the cab. Any ideas?
Genesis fault code info for F340 + F345 attached.
Attachments ---------------- Genesis F340.pdf (135KB - 128 downloads) Genesis F345.pdf (136KB - 114 downloads)
