Search Forums | Classifieds (1) | Skins | Language
One more time---- what is the reason that "usually" 1st corn after corn is low yield?
jakescia
Posted 11/16/2007 20:16 (#239533)
Subject: One more time---- what is the reason that "usually" 1st corn after corn is low yield?
Oskaloosa, Iowa 52577
I have heard it said that the first crop of corn, following corn, is usually a low yield crop.
What are the "agronomic" reasons for this?
Because of N being tied up in the breakdown of the stalks from the original corn crop?
But, if enough N were put down with the stalks, and the stalks turned under in the fall, would that not allow the N enough time to break down the stalks, and be released for N to the crop?
What would be the case if the N were not applied until spring?
Or.........is there another reason that "usually" causes first corn after corn to be a weaker crop?
Reason for the questions----------I thought we put down enough additional N in fall and spring to compensate for the N that would get tied up in the breakdown process. However, our corn yields for corn after corn are not as good as I had hoped.
Late planting is certainly a factor------and we did not plant until first of June............but, we have not planted until then for about 3 years running........so, comparatively, ought to be similar.
Obviously, weather would have been big factor in 07----------but fields following beans held up pretty well.
Thanks.
