| Last year I conducted a few field trials using the product Coron, a slow releasing nitrogen with Boron developed for the landscaping industry. I used it primarily as a carrier for my post-spray Liberty and Roundup corn acres, at a rate of 2 gal/acre, approximately about 15 units of N. I sprayed two separte 160 acre fields, and both times sprayed the Coron in the center 80 acres with 40 acres on each side to use as a check. The results were great, a definitive 10 bu/acre increase using Coron and using the yield monitor and mapping system, a 14 bu advantage just using the 8 rows next to each other on each side of the field. The product did cost an additional $11/acre, but the revenues were greater at $2.25 corn. Now my salesman is telling me I will see an even greated increase in yeild if I team the Coron up with Headline. Has anyboy used Headline, Coron, or a combination of both??? What were the results?? | |
