Question for John..neAR on fuel pump adjustment.
RonB
Posted 8/8/2006 13:48 (#33811)
Subject: Question for John..neAR on fuel pump adjustment.
Going back to our earlier conversations about the fuel pumps on 8.3 litre's. You mentioned the following:
"Also, on the injector pump aneroid, rear side there is a allen head plug. remove the plug and find a star wheel similar to a break adjuster. Turn this wheel down (with a screwdriver)or until there is slack in the spring."
My question now appx. how many turns did it take you to get slack in the spring? I also replaced the supply/lift pump, it did not sound as strong as it did a few years ago.
Thanks John
