Search Forums | Classifieds (72) | Skins | Language
Wayne Pump with Furnas Pressure Switch
Dan_wcIN
Posted 9/10/2006 23:29 (#42908)
Subject: Wayne Pump with Furnas Pressure Switch
It made a Crop
Need some help the pressure switch on a 1/2 hp Wayne pump. It's NOT a submergable pump. The pressure switch is Furnas pressure controll. Basic unit (cut-in ) @ 20 psi (cut-out) @ 40 psi.
Anyway, the the pump runs when I bypass the pressure switch. Is there anything(s) to check in the pressure switch. Or do I probaly need to replace it in the morning. I'll just manually run the pump tonight.
