Search Forums | Classifieds (27) | Skins | Language
removing a 7720 radiator?
don@nebr
Posted 9/13/2006 20:40 (#43547)
Subject: removing a 7720 radiator?
I am in the process of removing my problem radiator in the 7720 combine to assess how bad it is and IF I need a new one or try to get it repaired. (Have a friend who says he can boil it and assess the damages, he is in radiator biz). it was leaking worse than ever today just on an easy ride home.
I have most everything stripped off of it the conventional way but still have radiator inside the 'green' box which includes the sheet tin above it, matching the hood, the fan shroud, and the main support box.
Does this WHOLE box come off as one unit??? I am out of taking things apart, down to spot welds and the upper and lower hoses YET. IF the radiator comes out of this box, HOW?? AND if the whole box comes off the A/C pressure hoses run right thru the metal box with NO other exit. IF it requires loosening the hoses and dumping the freon which is the old R-12 , I am going to cut the box to slide them out!! IS that required???
ANY advice on further removal is welcome!!! Thank -you!! --d--
