Search Forums | Classifieds (82) | Skins | Language
ideas for a 3 point mounted striptill bar running Dawn units
bigfarmerdave
Posted 11/13/2006 11:50 (#61107)
Subject: ideas for a 3 point mounted striptill bar running Dawn units
Eastern Iowa
We have been tossing the idea around of buying a 3 point mounted toolbar and putting Dawn striptill units on it. Any of you out there tried this or currently using one? We were thinking that a three point mounted striptill bar and a mounted planter (Kinze stack planter?) on a tractor running RTK might be just the ticket. The reason for wanting all mounted equipment is to eliminate as much implement drift as possible. Are there any pitfalls that we are overlooking with this idea? Going around corners might be a little tricky but we don't have much of that to deal with. Jim, I've seen a number of your pictures of guys running striptills with Dawn units but I don't believe that I've ever seen a picture of a threee point mounted one. Also, how big of a horse would you need to pull a twelve row Dawn setup with a dry cart in gently rolling ground?
