Posted 6/10/2023 21:56 (#10265032 - in reply to #10262080) Subject: RE: Enlist AMS & tank mix order
WC Ohio
Liberty 3# is the only rate that will make it work right. Clethodim will need COC and higher rate with the Enlist. There is antagonism between the 2 and the clethodim will not work very well. Roundup and Enlist you can get by with 1.5#. The order the enlist and roundup goes in doesn’t matter I usually put the Enlist in last but don’t have to.
