Search Forums | Classifieds (48) | Skins | Language
Furnace PVC condensate trap
povertypoint
Posted 10/11/2023 17:43 (#10436271 - in reply to #10431902)
Subject: RE: Furnace PVC condensate trap
SE SD
2" mip and bush it down to a barb fitting. clear vinyl tube, loop it to create a trap, then head it to the drain.
that thing is nothing special.
I'm guessing your working with a Hiel or tempstar
edit to add. I would be more concerned about the riveted heat exchanger.
any roll out in the burner chamber or yellowing of exhaust pipe (pvc)
I believe some of the NULK's had that issue.......BTW.......those heat exchangers have a life time warranty.
Good Luck.
Edited by povertypoint 10/11/2023 17:56
