Posted 2/11/2024 22:07 (#10619568 - in reply to #10619252) Subject: RE: Affordable grade control for link tile plow
NE South Dakota Clark, SD
Are you talking a just up down parallel like an old Wurdinger or Oconnell or parallel with pitch like Wolfe, Waynes/Crary or the updated Oconnell? I will add SD Drain to the list for you to check out as well. A complete new grade control system with RTK rover and base is going to start at about 25K and go up from there. If you already have RTK or are part way there it will be less expensive.
