Search Forums | Classifieds (130) | Skins | Language
Flow-X guidance lines-InCommand 1200
gpsdude
Posted 2/18/2024 17:37 (#10629201 - in reply to #10628177)
Subject: RE: Flow-X guidance lines-InCommand 1200
NE South Dakota Clark, SD
With that combination, snapping an AB or curve tack line while doing your first survey of a pattern will probably get you the closest to your "real Earth location." The Digifarm system is surveyed in to USGS monuments to the best of my knowledge. SF1 will get you fairly close and if your line spacing is off by a foot or so, it is no big deal.
