near Mtl, QC | As the title mention it, I want to add hyd drives to my 3600 12 rows planter for the dry boxes. I already in the past converted the seed meter to hyd drives (2 drives) and it's controlled with a 20/20 rowflow. 2 questions about what I would like to do:
1) I was thinking of plumbing them with the 2 already there. Is 4 hyd drives on the same outlet too much? Tractor is a JD 7730 if it matters.
2) I have 2 choice for the controller: find another rowflow boxe (because 1 only can control up to 3) or use a JD rate controller dry. Is there one or the 2 choice a better option? I already have a 2630 inside the tractor for the autotrac, so already have 2 display anyway.
TIA | |
