Northern Ky | I'm trying to add 4th and 5th section to Spra Coupe 4660, it has Integra for rate and section control. Wiring is all there in Coupe, added switches and valves. Removed a connector harness at control modules that changes it to 5 section. Connected small wires under dash to Integra harness. Integra now shows all 5 sections, will show them turning on and off in diagnostics but the original left wing switch acts as a master switch, if it is off the other valves don't work. Pump switch is set up as master. Anyone know what is going on? Am I missing something?
Edited by CederRidgeFarms 2/23/2024 11:52
