Posted 2/25/2024 09:05 (#10639085 - in reply to #10638448) Subject: RE: Intelliview 4 GPS Input
North Dakota
If your tractor has autopilot you can export nmea from the diagnostic port to the 9 pin rs232 port 2 on the back of the iv4.
If you want to use the TMX it can be plugged into the tractor isobus. My preference is to use the iv4/pro700 for iso control. If you need section control, applied maps or variable rates you need task control unlocked on the iv4. Cost about $850..
