| I'm coming from a Cruizer that output geo-located .kml files that showed application coverage when imported by Google Earth. Just bought a CR7 and as far as I can tell, it does not export that type of file anymore. Files in the Job File are object files intended to be read by another CR7 or specialty surveying and/or mapping software. Big step backward for me, as I do some custom spraying and the customer always appreciated a geo-located coverage map that also showed exact lat/lon location of flags marking drop pipes, drains, ditch crossings, debris, etc. If someone has a solution to regaining that function, I sure would like to hear it. | |
