Hennepin, IL | AL 6000 would be a good option, only downside is the cabling takes some customizing to power with the 2020. You want a mobile logging cable, not the regular single or dual port cable. A 6500 is an upgradable receiver plus it is dual band whereas a 6000 is a single band so wont track as many satellites around obstacles. Another option comparable to a 6000 just a little older would be an AL 15 or 1600. There is a harness from Precision to plug directly into one, part #727027. | |
