| pfortfarm - 4/7/2024 07:37
Current setting is 38400 and according to a 1500 manual I found online, that is the highest for an Integra. Would a different series of receiver help? This is certainly something that is not keeping me from spraying; just seeing if I could gain improvement.
All receivers "jump" some. Even the expensive ones.
What you see on screen is directly dependent on the amount of smoothing done in the display.
Ag Leader doesn't filter as much as JD for example.
Its really not hurting anything.
A GPS 7000 would be an improvement in accuracy, reliability and stability of signal if you want to spend the money.
Edited by redpower 4/11/2024 17:27
