Search Forums | Classifieds (91) | Skins | Language
External GNSS into raven?
sparrell
Posted 4/8/2024 12:10 (#10699181 - in reply to #10698898)
Subject: RE: External GNSS into raven?
Amc4life - 4/8/2024 08:48
Cruizer II RTK requires you to use the 115-4001-102 console cable. That has a "TO FIELD HUB" plug on it that brings in the external RTK correction.
I already have an Aman bt device plugged into that port for use with WI cors rtk. Is there a way to put both an external receiver and that into the field hub port?
