Search Forums | Classifieds (102) | Skins | Language
Raven Smartrax calibration problem
Amc4life
Posted 4/10/2024 20:31 (#10702142 - in reply to #10700908)
Subject: RE: Raven Smartrax calibration problem
Butterfield, MN
I'm wondering if maybe there's a short in the cable. I think the voltage for the disengage is shared with the same source as the engage switch, so you could also check for 12 volts between the two pins on the engage switch plug and see if any is there. If not, there's likely a short in the cable or the controller has an issue.
