Posted 4/11/2024 07:28 (#10702603 - in reply to #10702217) Subject: RE: Trimble to MF datatronic line transfer
Jeffersonville, OH
If the corrections levels are not RTK or close, you will have to adjust.
However, you shouldn't have to nudge, you should be able to center on the line, and snap it to the tractor position. and correct that way. Nudge should be removed from most Autosteer systems, they cause more problems than they ever help.
