Near Intersection of I-35 & I-90 Southern Mn. | Yes, the setup is determined by the configuration so that will be the same as before. Are you certain you have a problem with the Auxiliary Input Module? It may be an error in understanding how they work. I have a fair amount of experience with them and the default switch assignments are generally correct for most situations but can be changed.
If the error is in the setup in the configuration, you would likely have the same problem with another Auxiliary Input Module.
Have you tried making a new configuration from scratch. Redo absolutely everything, even those settings "you know are correct". It might just magically heal up. |
