Quebec, Canada | Sounds like the Drive isn’t getting GPS. Check if the FV adapter cable is plugged into Port A or Port B, then open up the GPS output settings and make sure that CAN GPS is being output from the port that the Drive is connected too. Here is a link to the CC1009K adapter cable installation guide, it has pictures of the menus showing how to get to the relevant section in the FMX. https://eng1e.seismic.com/i/duMdS4uZzAhIUwOSegUWPfKGu9qZIyGM9yrSnmmz...
If this isn’t the same FMX it would be good to check that the software version is 10.01 or higher. Earlier versions don’t output gps in a format the drive can understand.
And the last thing to try would be to make a new tractor in the equipment tab of the Cab App. Sometimes the equipment profile gets corrupted in the Cab App for whatever reason and building a new tractor gets the GPS to show up again. | |
