West Central MN | This is a twin bin AirMax (no auger). The two chains per bin basically function as half width section control (and maybe turn compensation too? I’m not sure). But yes there are 4 PWM valves and 4 encoders.
Based on shop teachers response this would be very difficult with a 3-channel module, unless I was willing to tie two of the chains together (possibly with some sort of cross shaft) and run them as one. Unfortunately with small odd shaped fields this isn’t a good option.
I think I’ll just be patient and try to keep an eye out for a used 5-channel module.
Thanks for the help! | |
