Search Forums | Classifieds (191) | Skins | Language
CaseIH 245 Magnum A/C Problems
brettwdmn
Posted 4/20/2024 13:30 (#10713495 - in reply to #10712925)
Subject: RE: CaseIH 245 Magnum A/C Problems
We have had the same problem with a 260 Magnum, it will kick on for about 2 minutes then wont kick on again until your restart the machine (does the same thing again). I did read somewhere that there is a ground on the left front of the cab under the floor mat that can get corroded that causes the issue, we just have not got around to testing that out. It would make sense as it is where most water would be collected, but we tested a different climate control module from a machine that works, no change, switches checked out, the thermostat checked out, and all other components. We ended up hardwiring the compressor to a switch for the time being, but it is worth a look!
