Search Forums | Classifieds (34) | Skins | Language
12 volt wiring questions?
johnk
Posted 4/19/2024 18:49 (#10712928)
Subject: 12 volt wiring questions?
ncia
I added a 60 gallon tank and pump on my field sprayer for a single fencerow spray tip. It has a small 12 volt electric pump that says 10 amps. Looks like it has 2 wires that are around 16 gauge . There will be 12-15’ of wire to tractor cab from pump. Power in cab. Questions are 1) what gauge of wire would you use? 2) I need a switch ,is 20 amp rated enough? 3) does it need a fuse between switch and pump? 4) I was recommended to have a relay between power source and new switch. Is that important? Thanks
