East central SD | A pro 1200 wont run a 1250 series planter as far as I know. We were told a pro 700 is needed to run the frame controls. Set our up with the 700 to run the frame controls and turning on vac motors and bulk fill. Pro 1200 to run the guidance and precision 2020 runs planter seeding operations.
Your 250 should have a wiring harness tucked away. Ours on a 340 afs connect was behind in the right corner panel. There is a kit available to put your 700 in that tractor from CIH. | |
