Search Forums | Classifieds (36) | Skins | Language
When do you replace your spray tips?
shulerfarm
Posted 4/23/2024 20:07 (#10716575 - in reply to #10716412)
Subject: RE: When do you replace your spray tips?
Holly Hill, SC
Not sure, never wore a set out. Pattern looks good and pressure close to charts. Sprayer pump will make up the difference if the tips are worn. I like the Tee Jet AIXR. My sprayer has 215,000 acres on it using multiple different tips based on rate required.
