Pequa drive install questions 7000 planter
jtd517
Posted 4/25/2024 09:02 (#10717329)
Subject: Pequa drive install questions 7000 planter
Installing drive on a 700 planter with the single cylinder. Looks like the mounting bracket needs to go where the transport lock is and no room to even get the ubolt installed with clutch in the way. Any tricks to mounting this bracket and where it should be located on the transmission? About ready to weld bracket to bar. Also, is it necessary to add the floating wheel kit hinge or is this an option? Not sure how skips will be if I do not install it on hilly ground and washouts.
Thank you,
