Posted 4/25/2024 22:03 (#10718086 - in reply to #10717916) Subject: RE: 4710 sprayer reading 100 + GPA
Mid-Missouri
You could set the rate to manual (pressure) and run some on a certain pressure like 50 psi. I am guessing flow meter is failing, or incorrect calibration number. I occassionally get incorrect and extremely high flow numbers, but usually when going from 90' to one boom section rapidly.
Does this 4710 still have the original stainless steel flow meter, or a more modern setup?
