Le Sueur VIA St.Thomas | I've seen this before, and maybe even have posted it here before, but it is still amazingly funny! I rarely 'cut-n-paste' but think this ones a keeper!
Subject: Tool Definitions
DRILL PRESS:
A tall upright machine useful for suddenly snatching flat metal bar stock
out of your hands so that it smacks you in the chest and flings your beer
across the room, denting the freshly-painted project which you had carefully
set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the workbench
with the speed of light. Also removes fingerprints and hard-earned calluses
from fingers in about the time it takes you to say, "Oh, ****!"
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs into
major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle ... It
transforms human energy into a crooked, unpredictable motion, and the more
you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If nothing
else is available, they can also be used to transfer intense welding heat to
the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop on
fire. Also handy for igniting the grease inside the wheel hub out of which
you want to remove a bearing race.
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles for
testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed your
new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good
aluminum sheet into smaller pieces that more easily fit into the trash can
after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot to
disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening old-style
paper-and-tin oil cans and splashing oil on your shirt; but can also be
used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted
screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you needed
to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a
kind of divining rod to locate the most expensive parts adjacent to the
object we are trying to hit usually smashing the thumb that is holding the
object that you are trying to pound into whatever it is that you are working
on effectively eliminating the need for manicure care on that thumbnail for
weeks. See: Son of a bitch TOOL
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons delivered
to your front door; works particularly well on contents such as seats,
vinyl records, liquids in plastic bottles, collector magazines, refund
checks, and rubber or plastic parts. Especially useful for slicing work
clothes, but only while in use.
Son of a bitch TOOL:
Any handy tool that you grab and throw across the garage while yelling, "Son
of a bitch" at the top of your lungs. It is also, most often, the next tool
that you will need.
good luck -jim
Edited by guessrow 1/11/2010 21:14
