Elizabethtown,KY | NCSteveH - 6/29/2010 20:28
What about a Super-H with tricycle gear that does the road gear wobble?
Try taking the top off the steering gears out front, if possible take the big gear off and rotate it 180 degrees to less worn places on the gear. You could still get this gear new a few years ago, I haven't worked on one for a few years, so you might check availability of both new and used. I've had good luck doing this, also had to put a new thrust bushing on the bottom of my 350. |
