Alberta | Just wondering if anyone has hooked a non case receiver to the AFS pro 600 display. They have a 10 pin connector in the harness and you have to buy a 10 pin to 9 pin RS232 cable for $100.00. All I need to get into the display is the tx signal from the receiver and maybe ground, so unless there is any terminators or funny things I was going to build my own cable. Just need to know what wires are TX, grnd etc.
Also does anyone know where to get a wiring schematics for the cab, just hooked up the cb and wanted to make sure I used the proper power wires.
Thanks | |
