Search Forums | Classifieds (40) | Skins | Language
Sense of the crowd: AFS versus AgLeader
torn
Posted 8/1/2007 21:47 (#181582 - in reply to #181504)
Subject: RE: Sense of the crowd: AFS versus AgLeader
roaming
Arnie - 8/1/2007 19:53
I agree and would add that if you are going to get a new CNH combine you might very well be forced to use their monitor as it is fully integrated into the combine for yield, fan speed, rotor settings etc.
Only true of the 7010/8010 combines. On the 2500 series, the Pro600 is only used for yield monitoring, so if you replaced the AFS system with an Ag Leader yield monitor system (sensors, Insight, etc.), you would not lose any other combine functions.
