Garmin etrex legend recieving WAAS ?
CB In The Cab
Posted 8/3/2007 11:14 (#182297 - in reply to #182121)
Subject: Re: Garmin etrex legend recieving WAAS ?
Central To Everything and Close to Nothing
Some Etrex models are WAAS enabled but don't fool yourself thinking it is as accurate as an ag guidance system using WAAS, ie. sub-meter. I have an Etrex Vista C and with the WAAS turned on the accuracy will improve to 2-3 meters vs. 6-7 without it. Since the new WAAS birds went up, I have been able to get a differential correction but up until then I could not in this part of the world. I found that with the WAAS enabled but not recieving any signal, the accuracy was worse than if it was shut off. Just my two cents.
