Original Greenstar display update
GreenDude
Posted 8/22/2007 15:09 (#191461 - in reply to #190243)
Subject: Re: Original Greenstar display update
The Original GreenStar Systems Updates are now available on Stellar Support under Support and Downloads or Quick Support. The best way to get them is by downloading them to your desktop, then run the updates to a keycard from your desktop. If you do not have a keycard the updates can be ran to a datacard, but you will need to re-run the updates to datacard once you are done updating the system. This will restore datacard back to normal. Then you can put the card in your processor and updates should run automatically if you are programmed to anything other than yield mapping.
