Central Kansas | I want to use it on the 8200 for stripping/planting, do you notice a lot of wiggling or wide narrow rows? I have used the SF2 just on manual guidance for a year now and it seems like I just chase it back and forth. You look from the end of the field and the rows look straight at first glance, but when you stop and look it just wiggles all the way down the field. I was hoping to eliminate that. Would be running on mostly flat, fairly smooth ground. Any help is appreciated.
