Search Forums | Classifieds (52) | Skins | Language
EZsteer...bonkers again
houghta3
Posted 6/4/2006 10:18 (#16905 - in reply to #16804)
Subject: RE: EZsteer...bonkers again
Saginaw Michigan
sounds like a stuck gyro. had one doing what you describe. we stuck a different controller on, calibrated the T2 and it worked perfectly. put the old one back on...worked ok, then would go crazy.. when you are travelling strait on your line (in reality) does the lightbar indicate you are off(obviously).... is your steering arros strait, parallel to teh line, or is it travelling along the line but cocked one way. is wierd to see. this is what we were seeing. i would contact your dealler and see about trying a different controller
hope this helps
-mike
