Search Forums | Classifieds (55) | Skins | Language
Cat mt755 Ez steer bracket?
Posted 9/11/2007 10:37 (#201977 - in reply to #201832)
Subject: Re: Cat mt755 Ez steer bracket?
The indent in the steering wheel is really not a big problem. Steering wheel only moves a fraction of an inch to keep the tractor going where it needs to go. When first getting it dialed in, I did have it try to turn so sharply that it ran the steering wheel over to the indent and then the little servo just sat there and spun as the tractor did too. As you might imagine, such a situation is not acceptable but it wouldn't make any difference if you had a round wheel either. If the tractor turns that abruptly, you really don't want to be riding it -- especially if it is pulling a trailed implement.
Antenna has been relocated and the settings dialed in so I don't think there is a tractor out there, whether hydraulicly coupled, CAN-Bus coupled, or servo actuated that holds or acquires the line more smoothly.
