Search Forums | Classifieds (83) | Skins | Language
Have Yield data missing, need help JD Grn*
Francis
Posted 9/22/2007 07:31 (#207602 - in reply to #207591)
Subject: Re: Have Yield data missing, need help JD Grn*
Redfield, SD
When you did this was the time displayed at the top of Run Page 1? Recording simply means that the header was low enough to turn the acre counter on. Was this processor used for any thing before you installed it in your combine? If so, did you reprogram it to Harvest Doc? If seen this happen and the data was never recorded. Was the data you were seeing under Info Harvest Monitor Field Totals? This data is stored in the moisture sensor and can be viewed but doesn't mean that it is mapped.
Edited by Francis 9/22/2007 07:32
