Search Forums | Classifieds (89) | Skins | Language
AgLeader GPS 4100
torn
Posted 9/28/2007 22:56 (#211393 - in reply to #211300)
Subject: Re: AgLeader GPS 4100
roaming
Which OmniSTAR signal? VBS, XP, or HP?
Universal Display or Display Plus? Do you know what version of firmware is in the display?
If it's an original Universal Display and you're talking about OmniSTAR XP/HP, then you're out of luck. None of the UD firmware versions can accept the NMEA quality message from the high-accuracy OmniSTAR signals (or RTK). If it's a Universal Display Plus, then you can update to version 31.4 firmware, which is the only monochrome firmware that is compatible with XP/HP/RTK.
If you're talking about OmniSTAR VBS, that's a different story. Any of the displays should be able to work with that...
