Central Illinois | Almost sure it will support 128K Compact flash cards, As far as how many Hours of data I am not sure, but unless your doing all curve path or logging elevation data . the only time u use the card is to set your A and B cordinates all other passes are based off your old a, b points every time you open that job. Also make sure your card is clean of any data , Autofarm sometimes has issues with unrelated files on the cards. | |
