Search Forums | Classifieds (79) | Skins | Language
AFS Pro 600 vs. AgLeader Insight
GPSNUT
Posted 12/12/2007 11:55 (#258311 - in reply to #258167)
Subject: RE: AFS Pro 600 vs. AgLeader Insight
The AFS Pro 600 is easy to use. If you use the Insight on a Case IH combine you might have to change the sensors also. Have your dealer order you a DVD on the AFS Pro 600. The DVD is DMC part number DVD10893. The DVD is really for the AFX7010/8010 combine but sections (setup & precision farming) will apply to other combines. The DVD will show its features and how easy it is to use.
