Search Forums | Classifieds (14) | Skins | Language
Deere monitors
CB In The Cab
Posted 12/18/2007 13:58 (#263188 - in reply to #263172)
Subject: Re: Deere monitors
Central To Everything and Close to Nothing
The JD 2600 is a certified ISO 11783 Virtual Terminal so you should be able to plug your planter in and it show up on the display with full functionality. You may need to add an ISO implement connector harness to your exisiting GreenStar harness but that is nothing complicated to do.
