Search Forums | Classifieds (85) | Skins | Language
Raven Envizio Pro vs Trimble 500
trdoo
Posted 12/21/2007 09:15 (#265378 - in reply to #265228)
Subject: RE: Raven Envizio Pro vs Trimble 500
If you will always have the 500 in the tractor when spraying I would drop the 450 console and use EZ boom. You will still need the raven cables to hook to the EZ boom. The only catch would be if you end up needing the 500 for another operation while spraying the EZ boom would be rendered useless because the 500 is your display.
Basically the same thing with the Raven system.
Both swath control systems work real well and you would probably be happy with either one.
