| The 132 in the name suggests that it is a 132 Trimble. If you are lucky. it will be as simple as going into the configure menu and switching it to beacon. Omnistar does sell Trimble receivers, but I doubt that they would sell a Omnistar branded one that has the beacon or WAAS capability intact. I would next try to upgrade the firmware from Trimble's web site. If that does not work, then a level four Trimble service provider (like http://www.agexpress.com/ ) may be able to install Trimble programming. If it did not come with it, then you will also need the Trimble Beacon/WAAS/Omnistar (high dome) antenna. | |
