Search Forums | Classifieds (98) | Skins | Language
Possible to make a shallow well deeper?
sri
Posted 1/7/2008 00:55 (#277502 - in reply to #274895)
Subject: RE: Possible to make a shallow well deeper?
nw pa
  put in a call to your local utility. If it's rea they may come out and try one of the holes for you.i think they can go quite deep.  May have to clean the well of some exces dirt and mud when they are done ,. But it will be deeper.  Also if the bottoms are sand and small gravel use a high power pressure washer and a trash pump to clean it out. The pressure washer will break it loose and the pump will get it out.make a big enough hole to put something smaller inside.
